Automotive electricity
My car turns on but turns off.
Moises007
Good friends (as), I have a problem with my car, it takes a long time to turn on when I give Star it takes about 8 seconds to start, and it manages to start with failures, once it starts, if I do not keep it accelerated it turns off immediately when removing the feet of the throttle; I would greatly appreciate your help Regards. Lancer 2004. 1.3 4g13 engine
Mangel HH
Mangel HH
19.786
Hi Moses. The use of the scanner is suggested to see if there are stored codes. The posibilities. 1- Poor fuel pressure. 2- Temperature sensor does not send signal to the Ecu to adjust fuel injection parameters. 3- Crankshaft sensor with dirt, does not take movement signal to send to the central and the ignition is delayed. Salu2.
Moises007
thanks friend the scanner when connecting it error comes out, the ecu does not tell me that the mechanic tells me that it is because of having several things disconnected ... ruled out damages in the ecu since it was repaired and sends all the signals to check the sensors as you tell me, the mechanic told me that there is a fault in the internal fuse box but nc if that would be affecting
