the problem is that it starts and does not pass the 3 thousand turns gives me the following code16706 engine regime transmitter without signal. static if someone could tell me what this fault corresponds to? Thanks a lot
It is the rpm sensor located on the top of the flywheel of the engine in most VW, do not indicate what model it is.
The other option is in the front crankshaft pulley.
