Automotive electricity
Hello, Mercedes C 220 stops regulating and brand check engine fails.
FAS06
FAS06
16
Hello everyone, as a Mb c 220 said that when it is idling after a while it stops and marks check engine. The scanner marks a common rail fault. Some clue?
MECANICA AUTOMOTRIZ LLOVE
Specify what year, what engine please.
It does not specify what year and if the engine is diesel or gasoline, or what cylinder capacity.
FAS06
FAS06
16
It could be solved by replacing the primary pump, thanks for the input. Greetings
Carlinonda
Carlinonda
3.609
Controls fuel pressure in the rail.
FAS06
FAS06
16
Hi Carlionda, thank you I will try
Greetings
