Before changing the ECU, check the RPM sensor if it worked well and if the Sensor _ ECU circuit had continuity.
You checked if the ECU was positive.
The engine is not immobilized but on the board marks a witness with the drawing of a key.
good morning friends I already have the solution of the problem not to turn on focus and kilometrage erase is just a relay that goes in the engine compartment that relay sends a signal to the computer that is my email for more info junior_1m@hotmail.com
