Automotive electricity
Spark plug cleaning
audiotest
Hello, a simple question, how to clean the spark plugs of the car, some say they are not cleaned, they change, well but I guess when they are already very used. Thank you very much
Arkos
Arkos
128
Look you can pass a toothbrush copn a little gasoline to remove the grease or ollin and then sand the contacts a little and you have first
Mangel HH
Mangel HH
19.786
Hi. Spark plugs are changed when the end of their useful life is determined. The cleaning will depend on the condition that they present, generally in a very short time they will come back in the same way depending on several factors, for example, poor combustion, general state of the engine. Attached. https://www.ngk.de/es/tecnologia-en-detalle/bujias-de-encendido/diagnostico/fotos-de-bujias-danadas/ Salu2.
