Automotive electricity
temp clock does not work.fiat siena
marcezeppelin
good the temp does not mark me. on the board. I ask a question. If I bridge the card, what goes to the board? the needle would have to go to the maximum ?. another. if with the tester in resistance. I put it 1 at each point of the sensor. Would I have to mark something? obvious. With the hot car.
charly48
charly48
1.712
If you ask for help you should have some common sense and put at least the basic data of the engine so that the one who tries to help you does not have to be guessed what it is, the siena has three different types of temperature sensors and all with functions and different capacities, there are two-pin green, black three-pin and black four-pin.
Carlinonda
Carlinonda
3.609
When you say bypass the board tab will mean that you put the only cable that has ground. The temperature indicator sensor of the injection system is the one with 2 terminals. The one on the board is a terminal.
