Automotive electricity
alternator connection to coil and regulator
Elen Ojeda
I need to know how to connect the coil to the regulator of a fiat 133 mod 81
Ennio Montenegro.
Elen
Which coil do you mean .. ???
The alternator and regulator are clear.
Elen Ojeda
hello I posted some pictures for you to see
Carlinonda
Carlinonda
3.609
The positive of the ignition coil (+) goes parallel to the Ignition terminal of the voltage regulator, the field terminal goes to the positive brush of the alternator. This regulator is not suitable for the charging indicator lamp. If you are interested I explain an alternative with a voltmeter.
Elen Ojeda
I do not understand that the lamp would not work when I contact the battery light
Ennio Montenegro.
It refers to the battery charge warning light.
