It is already underway, although the eco mode was activated by a leakage of energy and the lack of the harness that did not start was a different issue, the base of the transmission whip (automatic) broke down and lacked pressure causing the rod it safara, the car remaining with speed remembering that the indicator did not appear anything for that reason did not start and did not remove the safety of the gear lever, fortunately it was not the BSI, and conclusion were two different problems that appeared in the same moment, thank you very much for the codes that will try to solve it shortly.
Thank you very much for the data, the technician had told me that those codes were for other situations, in fact the car at times kicked or skated the speeds I also saw that code p1710 referring to the wheel speed, possibly a wheel speed sensor defective or the reluctor (reference teeth), since as the brake control (ABS) is directly related to the transmission, I now think that I will check all the electrical lines that put the harness that I already got and check who will drive the scanner you tell me and take the BSI to repair
The P 1710 code is specific to PSA Peugeot and refers to transmission problems only.
The only relationship that the automatic transmission has with the ABS is to share the signal of the speed sensor (VSS) through the CAN network, beyond this each one decides his or her actions individually.
The damage I referred to about the BSI does not require electronic repair, but reconfiguration with a scanner.
