Ok mangel thanks. It will be necessary to clean the gasoline bonba and the car was also stopped for a year but before it eased well. if I walk a battery of very low power, I clarify 85 anchors, but the car starts. Pedal does not assert and better turns off. What beo is that a relay is missing in a fuse box. Dense call but before Asia is not missing.
Suggestion. The vehicle remained stationary for a year, during this period the fuel degrades, losing its properties and accumulating residues at the bottom of the tank, which when the pump is operated, its suction filter can become clogged and cause failures. In the same way, change the fuel filter and, if possible, clean the throttle body and check the condition of the spark plugs.
Salu2.
