Automotive electricity
Alternator indicator light does not turn off
ELECTRÓNICA FCJ VENEZUELA
Good morning, my colleagues, my question is the following: I changed the focus of the indicator light on the operation of the alternator of a Chevrolet Celebrity vehicle by a LED, but now when I turn on the vehicle, the LED does not turn off as it should, what will be the problem?
Mangel HH
Mangel HH
19.786
Hi. But before switching to LED, did the light work well? It can happen that the normal lamp provides the excitation resistance that the alternator needs, therefore the LED with another characteristic does not fulfill that function being always on.
Hi Mangel if the original lamp did turn off but it almost didn't show and I wanted to change for a LED but it doesn't turn off
BIN2013
BIN2013
2.689
friend the led works differently because it is a diode !! you have to use the incandecent lamp that corresponds so that the alternator turns it off
Ok friend BIN2013 thanks for your explanation, regards.
