Hello forum boy I have a Fiat dune diesel. Md 98 I was driving and stopped suddenly Check the selenoid is fine Check preheater is fine. Some help gas oil has
Or you can also start by checking with a test lamp if a signal arrives at the injector pump solenoid, if there is no or the power is cut, it will stop suddenly and you will not want to start.
