Automotive electricity
Light problems
Nicolashsb
hace 6 años
hace 6 años
Hello I have a vw gol diesel mod 96/97 I fear problem in the lights when I press the brake the intensity of the lights lowers and when I signal lights the stereo turns off ... and so on. They live blinking constantly. I heard that a rifle relay is loud, one that is long. Isn't that what it will be? Can you help me .. thanks
Mangel HH
Mangel HH
19.786
hace 6 años
hace 6 años
Hi. Start by checking the body's soil, deficiency in it, loose anchor, with rust, battery terminal and / or sulfate cable. The next step is a possible shunt to ground in wiring or lamp holder of the brake light and / or light circuit. Salu2.
Nicolashsb
hace 6 años
Hello I have broken the beacon flasher will be that that produces the lights .. now the car turns on and does not turn me on anything nose that happened .. could you give me what could it be that now nothing turns on
Mangel HH
Mangel HH
19.786
hace 6 años
Check the fuses, if you find burned there is a short in the circuit, including the beacon relay.
Nicolashsb
hace 6 años
Hello, because when I turn on the car everything goes out. The stereo lights and the electro does not start ... when I turn it off, the car turns everything on again ... what will it be? What is the ignition fuse? Graciias
