Automotive electricity
gol trend 2010, accelerator
vergara
vergara
12
hace 6 años
hace 6 años
Hello, I have a 2010 trend goal with an electronic accelerator, very rarely it is a bit locked, as if it were that the cable is a little locked and then loose, as if to have an idea! But being an electronic one I don't know if it is a problem of dirt, bad contact or device failure From already thank you very much
Mangel HH
Mangel HH
19.786
hace 6 años
hace 6 años
Hi. It is important to verify the Tps with the multimeter in addition to checking your contacts for possible dirt or rust, it is likely that there is a voltage drop or variation in the track of the same that causes this situation. Salu2.
