Check the battery voltage, if it does not reach 13 volts, it has no charge, when it must start, with the cold weather, the donkey must drag a frozen motor with viscous oil, ask for so much power that the power falls below the 11 volts, so the spark is not enough to ignite the cold gasoline, (it does not volatilize due to the low temperature) and the donkey keeps asking, The battery dies, the car does not start and you, l. .p. .q ... p .. you get angry and it's worse. luck
