I am with the clio .. check all the fuses and relays, they are all ok .. disassemble the ethereal and air part .. now they turn on everything ok until the contact ... and when I give it the touch to start all the lights go off lights, you hear the relays that come in contact, but nothing happens ...
The quilmes luckily did not heat up, but now some isenbeck accompany ... I will check the land and contacts
