hace 6 años
Hello community I want to ask you a question I have a gli model 97 1.8 goal with air which out of nowhere I stop walking, take it to a technician and load gas product that I did not have but here the problem began, the compressor did not reach tension I took it to an electrician who was recommended by the technician and verified that the compressor was working perfectly but as I said before there was no tension, I left it and after a few hours he called me saying that he had finished it and told me that the platelet had burned of the air and I put a key to turn it on by canceling the original one I charge $ 1200 and I wanted to know if I did not get stuck and the only thing he did was to place a new key because the one that was not working and another question is there is an air plate I suppose it refers to a printed circuit with components and I do not chamullo. Of course thank you and if you can help me I would appreciate it to tell you that that electrician is a chanta
