Automotive electricity
vignettes de chevrolet corsa 2
jorge horacio bigatti
hace 6 años
hace 6 años
hello friends I have a problem in my vehicle I do not work the beacons and I do not have the slightest idea that it may be I would like to know what is the reley and fuses of beacons and what they are and if it were anything else I would appreciate your help from ya thank you very much
Carlinonda
Carlinonda
3.609
hace 6 años
hace 6 años
The beacons and spinning lights work with the same flasher. You work well turning lights, also the beacons and turning lights have independent fuses, check them.
hace 6 años
ok I check all the fuse since the spinning works me then I tell you thank you very much
hace 6 años
hello friend check the fuse and they were all well and ye found the problem and removed the key and the keys were dirty and checked the key tab and now it is working thank you very much for your help from now thank you very much
