Thanks for your contributions but I have another question, is it necessary to remove the manifold? Porq I fixed and the diameter is slightly smaller than the arrow of the bearing, also I do not want to damage the manifold because they do not sell them here, so, if I understood correctly I have to break the bearing and finally remove the inner ring?
Dear, if you do not get a collector you're going to run a pretty risk. If the bolillero is not engaged or broken, you could carefully lift the shield cap, wash with gasoline, lubricate with grease and re-cap. Humble opinion.
