Automotive electricity
How does the installation of alternator of a jetta A3 or MK3
Fernando97
hace 6 años
hace 6 años
If someone could do or show me some diagram as the alternator connections are going to be much appreciated
Carlinonda
Carlinonda
3.609
hace 6 años
hace 6 años
This is a page that is in Argentina because they are dedicated to manufacture voltage regulators, check if your alternator appears with the voltage regulator or voltage regulator and there indicates the connections. Look at the part of catalog. www.nosso.com.ar
danielledesma
hace 6 años
hace 6 años
The screw that says B + is connected to the positive of the battery, then you have a plug with two terminals D + and W; the D + goes to the charge indicator on the board, and the W to the count turns
Fernando97
hace 6 años
Thank you very much for something like that!
But I had not confirmed
