Automotive electricity
ELECTROVENTILADOR GOL POWER 1.6
chaqueñito
hace 6 años
hace 6 años
GOOD GOOD FRIENDS ... I COMMIT YOU WHAT HAPPENS TO MY GOL POWER ... WORKS OF THE RAYITA OF THE 90 ° A MASARRIBA ... IS MADE TO ME THAT IS A LOT OR NOT {? SOMETIMES IT'S LIKE NOT TO START THE FAN ELECTRO ... I NEED TO HELP ME TO RESOLVE THIS ... UNTIL NOW I ONLY WAS ABLE TO GO TEMPERATURE .. LUCKLY LUCKLY SEIZE IT AT TIME ... SINCE AFTER THAT'S WHY I TRAVEL 150 KM NORMALLY ... IF SOMEONE CAN TELL ME WHAT TO DO ... OR HOW TO PUT A DIRECT KEY TO MAKE IT START FROM INSIDE .. EVERYTHING YOU CAN TELL ME TO STOP THIS THANK YOU
Mangel HH
Mangel HH
19.786
hace 6 años
hace 6 años
Hi. The bulb of the electro sends signal to turn on to 92nd and cuts to 87th, the thermostat starts to open at 87th. Then some controls would be established on the system and circuit of the electro, for example possible deficient contacts (rust and / or dirt, of the connector, in the same way of the respective relay, use clean contact spray and wiring). The system is reliable if the whole unit operates in time and form. In the same way the interior temperature indicator is not precise, for this a laser thermometer is used, you will obtain a reading of the real temperature of the motor and compare it with the first one. The correct and suggested is to maintain the originality of the factory. Salu2.
chaqueñito
hace 6 años
Could you tell me what is the relay of the electro fan in the power goal 2009 1.6 naphtha?
Mangel HH
Mangel HH
19.786
hace 6 años
In the fuse box there is an orange relay, that is the first speed of the electro, behind this you will see a black one that corresponds to the high speed. Check the anchors and connectors.
chaqueñito
hace 6 años
from 10 friend thank you
chaqueñito
hace 6 años
hace 6 años
solved
