Automotive electricity
corsa burning fuse
mauridjm2014
hace 6 años
hace 6 años
hello friends, a corsa gasoline year 2004 burning fuse q fueled on check engine, partia engine and then burned fuse .. now no longer part, there is current in spark plug wires ... some technical guidance.as you can check the pump of fuel ... I can assume that something is taking too much current or is short ... some electrical diagram is appreciated .... thanks the fuse that burns is 19, when it is removed, the check engine turns off ....
Mangel HH
Mangel HH
19.786
hace 6 años
Hi.
The fuse that burns is the one of the pump or the number 19?
mauridjm2014
hace 6 años
if it is the number 19 .. when you get it, the estimated check engine is turned off ... I do not know which one is the pump ... I do not have an electrical diagram to discard ...
Ennio Montenegro.
hace 6 años
If when removing the fuse, the check engine is turned off, the FUSE IS NOT BURNED.
Mangel HH
Mangel HH
19.786
hace 6 años
hace 6 años
Hi. The fuse 19 protects the ignition system but above all the ECU. What exists is a short circuit in the fuel pump in the first place or even a ground in the oxygen sensor that is given in many cases due to failure of the wiring exposed to temperature.
