Measurement tools
Good evening my brothers, I have a big problem with multimeter JM70A
Hi my brothers in electronics, I have a big problem with a multimeter JM70A model which is the following: I had the battery discharged uses two batteries of 1.5v each I was measuring some resistance, and the test went out for lack of battery I have a small adjustable power source which is connected to the multimeter to place the three volts already on some occasions I had done it to solve while I got the batteries (eye) for laziness but that day I neglected and placed 9v accustomed to the other multimeters that use 9v batteries was an oversight of mine. Okay the same when placing the 9v turned on and quickly the screen distorted and turned off, disassemble it completely and I realized that one of the fuses was open because it uses two, take out the display and take advantage of cleaning it with isopropyl alcohol as they do in some in youtube videos. Once the fuse has been replaced, the display turns on very well, so that I can see the screen, I have to put it in front of it, you can't see anything, check component by component and everything is fine, I think that the bad is the elastic belt that does not let the screen does not show the numbers in black, if you could help me please this way I appreciate it, although the tester does all its functions but the problem is the screen is blue auto ram excellent multimeter that would like to repair it or take it somewhere Where you can put your hand, I am again Sparta uses a black integrated round as a chip will be that of the problem ...... I already have time as an electronics technician but as I said I would like to save him from that problem .... .
is similar to is
mempun
mempun
1.985
These that carry the integrated round black are not repairable. It probably broke down without repair, the 9V were excessive for its 3V power supply.
hello thanks for the answer brother. by chance you will not have the diagram of that multimeter I do not know how to place a photo here so you can see the multimeter well
mempun
mempun
1.985
I don't have it, but I put a picture, in case anyone has it:
http://jcmelectronics.com/es/tools/multitesters/60-jm70a.html
it's similar to that
HELLO BROTHER Good afternoon I have a fault with an LG TV 42LK450-UB. which when being on after 6 minutes the TV the image begins to appear vertical columns of a width of 10cm two columns in the middle of the image one green and the other red, when I turn it off it is removed when you turn it on again the tv is heating in its function the columns are replaced. clean all straps that go to the tcon card with isopropyl alcohol and the fault continues and the same way I moved several times all the brown straps that are connected to the screen and the same
