Measurement tools
TESTER 9205A MISSED THE FARADIOS THAT WOULD PASS
jose3000
hace 6 años
hace 6 años
GOOD AFTERNOON I have a problem with this instrument, what happened is that I put it on a capacitance scale and I was measuring the filters of a TV, I had 5 minutes of turning it off and it had a sound that filter, I put the pins and they stayed in O BUT later It started with a value of 0.28 and 0.29 and from there it did not go out I measured another fan capacitors and nothing just marks those values I took it to amperage scale and marked 00.6 I tested a charger and it gave me 1.17 less that value gave me 1.11 that era The value that I used to take before them was the same with 0.06 in voltage, I turned it off and on and it was peeling the battery as if it were already drained, measured the voltage and gives me 8.52 volts. I put another new battery and I am still pipilating that it could have happened since I did well as the cables were ivan the filter was 100 uf the one that hurt me this had it on a scale of 200 uf annex images of the same [url=/ver-adjunto/aHR0cHM6Ly9hZGp1bnRvcy55b3JlcGFyby5jb20vZGVmYXVsdC8wMDA0LzkyL3otNzI1MTguanBn[[img[/js/ckeditor/plugins/attach/attach_25/pz[]
mempun
mempun
1.985
hace 6 años
hace 6 años
The capacitance measure does not forgive mistakes. It probably broke down.
jose3000
hace 6 años
Everybody knows this multimeter, but clarify something to me the manufacturers in each range places you that never exceed the limits of pritection indicated in the specifications of each measurement range and speaks of a 200ma / 250v protection rifle and speaks fuses rarely they need to be replaced and they are almost always burned by operator error and if my logic does not fail there will have to be one in each scale because otherwise voltage amperage and ohmeage will be damaged and it tells me later replace the fuse only with the specified voltage and ratings of stream, I have to translate with someone
jose3000
hace 6 años
what fuses do you mean menpun thank you for responding
mempun
mempun
1.985
hace 6 años
Fuse protection is only for intensity scales (A), for the others not. When voltage is applied by measuring capacitance, the multimeter invariably fails because they do not carry protection (well, they carry it, but small).
The voltage crosses the capacity circuit and reaches the main part of the multimeter, breaking it without repair.
I say all this without seeing it, of course, from the experience of having repaired many.
mempun
mempun
1.985
hace 6 años
It is clear that the capacitor you measured was charged with tension, you should have downloaded it before.
jose3000
hace 6 años
I confided menpun I had left it half an hour off, a friend arrived I turned it on and heard a filter sound did not pass 3 minutes I put the tweezers and until there it was, the beautiful thing is that I managed to repair the Samsung Pro TV, it burned that function but save to tv, what you say after downloading it before was tired of placing refrigerator and washing machine capacitors without downloading it, but there the manufacturer says that I didn't tell you, WHEN the measurement is done on the TV or switched, the circuits of power always rcde q there may be high d pulses at test point q they may damage the meter
jose3000
hace 6 años
hace 6 años
I do not know if I mistranslated what it is to commute for next time ha ha and when you mean fuses of intensity that is only amperage or voltage too, and well menpun it is clear to me that if I had never damaged it it was because it was only the capacitor, but here anything close to him could have damaged it since it was a plaque where it was, now I will have to study more English I saw the instruction but I did not give it much importance
mempun
mempun
1.985
hace 6 años
Intensity is amperage.
jose3000
hace 6 años
I mean that voltage is not protected
