Measurement tools
tester analogico ,se va de escala en ac .
Tester analógico HUNG-CHANG 3030S
joaquinenriquecorrea
hace 6 años
hace 6 años
Hi, I have an analog tester mod sk-110 (old) but in good condition, what began to happen is that it goes from scale to ac, this does it in three of the five scales it has, ie it goes scale in 1200,300 and 120v, the funny thing is that if I heat it up a little it starts to work fine, I measured R but I get it right, I clean it but it still does the same fault. NOTE: when it works fine (without the back cover) if the blow goes out of scale, I can orientate to give a solution to this topic, thanks greetings.
mempun
mempun
1.985
hace 6 años
If on the other scales it goes well (we assume), it seems a failure of contacts, I would check: 1) adjustment potentiometers that do not fail, 2) the switch that do not fail the contacts, 3) the resitences of the scales of A that are well welded.
Claudiogol
Claudiogol
3.027
hace 6 años
hace 6 años
https://elektrotanya.com/kaise_electric_sk110_sch.pdf/download.html in the diagram you have 2 diodes marked SD46 if one of them is failing and modifies its intrinsic resistance you will vary the measurement. Warm up with a welder and check which one gives you greater deviation. then the one of greater deviation replace it.
hace 6 años
Hi, I did the tests recommended, I even gave greater mechanical tension to the key but I did not succeed, the only thing that occurs to me to wash the key with some liquid because the internal part of the key I almost do not have access, isopo with alcohol, and I think that maybe it has some dirt that becomes conductive, thanks greetings.
hace 6 años
hace 6 años
Hi, I found the problem, in principle wash the plate with tiner but nothing happened, I remeasured the RY now appeared an R of 1.8mg altered the change and solved the problem, from now thanks for everything, greetings.
