Electricidad Automotriz
2015 ford transit does not start tank pump
hugo fabian
Good afternoon I have problems with the gasoline tank pump of ford transit mod 2015 starts barely two seconds and the positive is cut off. check all the wiring is fine fuses all but the scanner throws code B 1206 according to says group switchersfila 1 fault of circuit.agradesco any ayudita.graciass.
reyes saldaña rodriguez
and checked the safety switch that is in good condition, some vehicles bring it in the back in one of the polveras, usually activate in a sudden jump or in a blow,
hugo fabian
thanks for answering the switch I have not checked today check the whole engine and the switch is not there but tomorrow I check and comment.
hugo fabian
Good morning check the switch and this good clean all the plugs and connections and get gasoil to the ram, I'm just missing pulses in injector so I then check the rpm sensor.
