hace 16 años
encontre en un programa el procedimiento pero esta en ingles..te lo voy a pasar en ingles y tu te encargas de tradudirlo para no ir yo a equivocarme. paso 1. using a funtional transmiter, unlock vehicle and disarm anti-theft sistem. turn ignition on. depress and hold transmiter UNLOCK button for 4-10 seconds.while holding UNLOCK button, press and release PANIC button (before 10 seconds has passed.) paso 2---a single chime will sound to verify that RKE module is set to receive new transmitter code. within 30 seconds of chime, actuate any button on each new transmiter. after 30 seconds or when ignition switch is turned of (LOCK position), RKE module will end programming mode. paso 3-- once programming mode is completed, a single chime will sound. turn ignition of. verify new transmitter(s) operation. ESTO ES PARA LA CARAVAN 96
