Automotive electricity
Problem with LED headlights. Do not turn on LED lights on Chevrolet Bl
Miguel Delgado
I recently bought a couple of LED lights (9005 and 9006) for my truck CHEVROLET BLAZER model 96 engine 4.3, and when connected they do not turn on, it should be noted that the bulbs I had before halogen light (9005 and 9006) if they turn on. Who could tell me how to fix it? Thanks in advance!
Frankyfranes
Hello friend, these lamps need the positive to go with the positive and the mass with the mass, try to turn the connector, it may also be that if your car has a system of detection of molten light notice that there is low consumption and disconnect that line Marking Fused Light. Check that and comment, the halogens no matter where you connect the positive or the negative.
