Automotive electricity
Does not turn on internal goal ventilation
Diegovip
Good, I want to tell you a problem that I have with my goal Power 2007, from one day to the other I stop operating the internal air conditioning speeds, disarm the potentiometer and measure with the buzzer and in each speed there is output, voltage reaches it, change also the famous thermal fuse and still do not work (I clarify that voltage comes when I turn the speed knob). Any other tests I can do to solve the problem? Thanks in advance
Andres Perez Garcia
hello..but voltage arrives at the heating fan ... it can reach the potentiometer but not go out due to breakdown or dirt .. look if voltage arrives
Diegovip
Hello, the voltage reaches the potentiometer, it has an output at all its speeds, voltage reaches the resistance where the thermal fuse goes, which is the normal thing that is usually burned but it changes and the same does not work!
