Automotive electricity
Replacement of ckp in jeep 4.0
ziran
ziran
32
Friends of Yo Reparo. I greet you and I hope you are having a great time. I placed the CKP on my 4.0 jeep, only when I introduced it in the Hole that places it in front of the teeth of the Flywheel (toothed disk) I felt that due to its magnet it was pulled by the metal of this and I don't know if I should leave it glued to the teeth of the disc and tighten the adjusting screw in those conditions without damaging it by turning the Flywheel. Even if the CKP has the cardboard that is stuck on the tip of the CKP since I suppose that cardboard is used to leave the space between the teeth and the CKP itself and not be hit by damaging it. Or I have to move it back giving it more space. Friends. I hope you can help me. I am grateful for your advice Atte. ZIRAN
Frankyfranes
With a gap of 2 or 3 millimeters left is enough, just enough not to touch and make good reading.
Frankyfranes
What I see is that it has a slide, try to put it on the marks that the old one had if you are not going to vary the ignition
