Automotive electricity
Suran 2013
Aure.com
Hello dear, I am looking for the detailed electrical scheme, My problem arose after I had the air conditioning checked, the supposed "technician" made a short circuit in the pressure switch and opened the fuse 38. That is not so much my concern but that From that moment on, the airbag fault warning light is constantly on. I want to know if there is something electrically related, because I want to be sure if it can act accidentally or I just have to scan and remove the fault. sincerely. Aurelio
Richard
Richard
1.366
You should scan it, except in the event of an accident, the AIR-BAG system always makes a check when contacting and if everything is ok it turns off. The protocol used for communication between modules is the "CAN-BUS". What could be happening is that the can network has been out of sync. and that is solved by doing a proxy alignment (proxy-alingment) in the mentioned RED
Aure.com
Thanks Richard, I only have to repair the air because I knowing the subject a little bit this guy did a trick on making a short in the pressure switch and burning the fuse 38, I tried to lower the electrical scheme to get to the fault and I can't find it in the network the thermostat I am sure it is not, of course I remove the car but if I take it to the clerk this will be very expensive, thanks again I will try to get the circuit.
