Automotive electricity
hello what 134a gas pressures do I have to have in the gauges
mnr iny
what pressure do I have to have on the pressure gauges?
Richard
Richard
1.366
Hello, with 30º of temperature and the stopped car you should have more or less 100psi. But if you want to load it there are 2 ways: 1. The easiest with balance knowing the amount of grams it carries. the second is more complicated if you don't know about a / a. also the pressures vary depending on: if the condenser is clean, if the dissipating fins are not bent, the ambient temperature and humidity, etc. regards
mnr iny
very good thanks for the data I was in doubt because yesterday they brought me a kangoo and had the engine off 80 psi low and the same high and had in the workshop about 30 degrees of ambient temp
