Automotive electricity
Change polarity of the car headlight sockets to use led
Andrés723
Good day, I would like to know how to change the polarity of the sockets of the car since I want to install some led bulbs, but the polarities are reversed, the command that makes the change of lights sends mass signals, and the normal bulbs do the changes with current and have a fixed mass, can anyone tell me how the connection would be? The car is a Chevrolet Sprint
Ennio Montenegro.
Andrew What you should notice is the polarity that reaches the socket. Not if the positive or negative is interrupted. To change the polarity of the socket you must reverse the cables that reach it.
JulioCesarTorres
Depending on the power to be controlled, you could use a transistor to reverse the polarity, you can also feed the socket with constant positive, instead of massa constant
Andrés723
What I mean is that normally in a light bulb the pin on the left is mass, the one in the center is the high beams with a positive pulse, and the one on the right is high with a positive pulse, in this case it is the opposite of the pin on the left is positive current and the other two are with mass
Ennio Montenegro.
You have to reverse the cables that reach the socket.
BIN2013
BIN2013
2.689
Friend to solve that problem you have to use 2 relay and make a parallel circuit to the original is quite easy but they come led with common ground
