These engines do not have great mysteries at the time of starting, if there is good compression, the heaters work and diesel comes under pressure has to start.
If you start and stop alone, you have to suspect the fuel that does not arrive with sufficient pressure, try to loosen the nut that connects the injector with the pressure pipe, if giving a couple of seconds of starting spills a not very poor amount of fuel.
In case of not spilling it is necessary to check that the solenoid valve of the pump can lock the piston and does not let the fuel pass, do not trust that it clicks when it makes contact, since it can activate the electromagnet but not mechanically.
