good morning friends I share that after a long time I managed to find the problem that my car presents that is a Nissan Sentra 86, I explain the solution, I measured all the fuses and they were good, after a long time I decided to disassemble the fuse and it turns out that there was a slightly toasted wire and when I moved it I only had contact with the plastic with the fuse so the voltage did not pass, I put a new terminal and ready the board worked with all the meters, temperature, gasoline, brake light, ask for ways , thanks for your valuable help, I hope I can give you something of my experience with my nissan ..
