Automotive electricity
using a motorcycle without a battery damages any component?
fernando2959
My motorcycle has an electronic start already kicked. I am currently using it without a battery. Is it true that the regulator is damaged by not having the battery?
charlyesquisiarini
HELLO if it is possible that the voltage regulator or the stator may be damaged since they are constantly charging more when the battery is on, it depends on the model
JulioCesarTorres
In case of not using the battery, you can put in place a high capacity capacitor, about ten thousand micros or more, and keep the front light on constantly, this in case you use three-phase stator, thus avoiding overheating in the regulator of voltage, therefore its destruction ...
fernando2959
the stator of dakar 200 is an 8-pole single-phase mass insulated. Is the capacitor the same?
JulioCesarTorres
... yes, the capacitor is important because it keeps the voltage for the regulator stable, which if it would not help is the light on because in some cases the light for the light is taken from the front light current of a supplementary winding, however as I do not know the diagram of his motorcycle I can not speak with property, what if it worries is that it ends up ruining the regulator, since it would have to burn all the remaining power, which would raise its amperage, therefore its temperature ...
