Automotive electricity
24v alternator problem
Jonatan2018
Hello dear, I wanted to tell you that I have a 24v 60A alternator motorcraft brand, which loosened the carcass screws and the rotating rotor touched with the stator and broke the wires of the stator winding ... I also cut the wires of the coil going to the collector, which are one on each side ... seeing the winding that was in good condition what I did was solve that stretch ... The question I have is how much the coil must measure between the collector rings ... with the tester it measures me 13.4ohm and I was finding out that it should not exceed 5ohm ... honestly I know how many ohm it should measure. And if that "splicing" by welding eataño influences both the measurement. I would appreciate some information ...
Jonatan2018
Hello, thanks for the answer ... how would that mercury be by source and ammeter ... the coil is completely stripped of the carcass ... I need to clear all suspicion that the coil is bad and make sure that when assembling the complete alternator does not fail ...
hugodesalta
hugodesalta
2.450
To take consumption reading, as Mr. Torres tells you, put rotor, ammeter and source (it can be the same battery) in series. It gives you the consumption in amperes.
JulioCesarTorres
The resistance measurement in this winding is generally misleading, I have always preferred to measure the amperage, of course it is a bit more expensive, it requires a power supply, an ammeter but it is more accurate information, the normal consumption should be in about three to five amps
Jonatan2018
Thank you for the time and the predisposition ... I will perform the tests with source and ammeter thanks
