In the coil connector, the middle terminal is +, the other two are pulses, with one LED spot on one side of the connectors on the sides and the other on the positive side of the battery. Running should blink. If it does not there is no pulse.
to test the sensor of the follow-up it is similar, with an LED spotlight to one of the terminals and the other to +, starting it must blink if it is not so the sensor is broken.
