If another fuse carries a current cable to the reverse pear and connect it to check if it was the short of the pear back but did not burn the fuse! And the parking lights are working well, I don't know if that fuse feeds another system because I checked and I can't find the short
Good afternoon, I continue with the problem of fuse number 6, in the last revision I did I realized that the fuse burns is when I place the gear lever of any forward gear and revolutionize the engine a bit, in reverse and neutral it does not burn so I accelerate it, I put the gear lever or low in neutral and I put a change and it does not burn it only when it is strong. I appreciate who can help me.
