Automotive electricity
The precal light flashes. seat cordoba
hector jose diaz
Hi. It is a Seat Cordoba 1.9 hdi 2001 and all normal. I give contact, turn on the preheater light, a few seconds, start and it is marching perfectly. The problem is that after a minute the light begins to flash as if it were the turn signal light and so it goes on until the trip is over and I turn off the engine. I have knowledge of mechanics but little electricity. Maybe someone can guide me. From ya. many thanks
charly48
charly48
1.712
In addition to indicating the preheating timing, the loop light informs you of a defect in the system, probably a short heating plug.
Chuca
Chuca
394
Hello companion as you indicate the partner charly marks breakdown in those models is also due to two other reasons outside the heater system check that all brake lights work well if this is the case and there are no short or burned heaters check the pedal contactors of the brake these must be synchronized well comments and for any questions here we are
hector jose diaz
Thanks charly
