Automotive electricity
Xenon only turns on one by disconnecting the other.
trogster
I have placed two xenons in the low beam of a vw fox. Today I realized that I didn't light any of the two, the fuse is fine and the relay too. One thing I notice is that if I disconnect one of the wires that goes to the right lamp, the left turns on well. The same does not happen by disconnecting only the left, the right still does not turn on. What could be the problem and what tests can I do to find it?
Pancho Huertas
Don't forget to describe your problem correctly. It is in a car, a motorcycle, a child's car, a lamp of 12 vots. What is it?
charly48
charly48
1.712
In addition to what Pancho reasonably tells you, it is appropriate that you greet upon arrival, that you are not here at home.
Pancho Huertas
If assuming you have your lights, one A and one B in parallel, you disconnect A and turn on B, or switch on B and turn on A, it is because the power is poor; that is, not enough current arrives. You can use two lower voltage Xenon or use another source. But if it is as you say that it only happens with one, try to try the one that does not turn on the one that does, to rule out that it is short. I suspect you have a short circuit in which you disconnect to turn on the other.
