the problem as such is that the ecu has a damaged transistor which sends a pulse to the coil for piston 2 and 3 and also does not send me a pulse to injectors 2 and 3 i want to know where in the ecu card is that transistor to replace it since the ecu has a silicone that protects the components and does not allow me to access them to identify the damaged
the diagrams have helped me a lot to be able to locate the cables that are presenting the fault but the problem lies in the ecu they informed me that it is a transistor that is damaged because it does not send a spark in the piston 2 and 3 and does not send a pulse in the injector 2 and 3 what I need is the diagram of the motherboard of the ecu to be able to locate the transistors that are responsible for controlling that area and to replace them what happens is that the ecu has a silicone on the motherboard that covers the components and I do not want to extract the silicone arbitrarily but to be sure where it is
