Automotive electricity
Splitter Of battery. 900 volt
Eduardo aliaga calsow
Hi. B afternoon. I love you. Ask. A .favor. If they can. Help me. I want. Become a splitter. 900 volt battery How much .Has .Que. Be .The .Trainer. And. Use it for. So it works. Only .I have the .tenase .And the cable. I'm missing. What .Use .El. Splitter .Me. I made me. A charger. 12 volt 4. Amper. And .Me .Result .but I want .A patidor. From .900 volt to.tactor and .camion. Ante. Hand. Much. Grace
jorgedeclaypole1
Won't it be 900 Amps?
Friend. The. Drums. That I have. It is 850 volt. The charger. That I have. It is from 12. Volt. 4 amper is very slow for. Load. The. Battery that I have. It means. One week. To Charge.the one I have 850 volt
Sure. Have. Reason. 900amper Friend. Dissculpe Than. Needed. For. Do what. Grace.
jorgedeclaypole1
You need a 12 volt transformer with more heat to deliver more amperage.
Don. Jorge. 5183 And the bridge. Rectify How much it should be
Hi. Do you want a starter for the tractor / truck? Doing it will be expensive. They are coming already. Do you want to charge the batteries? You mention 4 amps. What do you need to do? Regards
Ennio Montenegro.
Edward You have many errors of battery capacity values; charging current and battery voltage. I have seen small tractors with 12V and 150 AH batteries and larger ones such as the D8K and D8N from Caterpillar with 2 batteries of 12V and 200AH each. As you say it is 900A, I would ask to be 900AH, but you should be sure of the voltage, because it could be 36V or more. The starting chargers, I have seen one of 200A, of 12; 18; 24 and 36V in high and low. Regards
Ennio Montenegro.
In MercadoLibre, for $ 200 you can have a 12 / 24V 400A charger / splitter.
Already. I understand .explained. I have one. Drums. 900 amper .yo. I became a loader. From .12 .Volt .4 amper. Y. No. It serves me by. What is it. Very. Slow. You me. They can. Help. For. Make me A. Splitter that .element. I need .To. Make me. One. Mi. Question. I. It serves. One of. 200. Amper. And .As .Se. It does. How much. It has .que .Ser .. 220 volt input transformer and .La. Exit. And the. Bridge corrected for your capacity. Before. Hand. Thank you very much
pato
pato
16.451
For so much current, welding machines are often used with a good rectifier, but with Enio's data, I think you are not passing the correct day because you do not know the subject and it does not make sense, the maximum I saw is two 180A 12V batteries serially for 900 amps sub-battery or electric sampi batteries are used and are very heavy
Don Duck 15793. 180amper consultation can be. Do. Walk. A truck. Than. Have. A. 850 amper battery
