Automotive electricity
Low headlights do not work Altima 2003
josé alberto zamarripa di
Hello Good afternoon, I have a 2003 Altima car, and I have the problem that the front low lights do not work, I already tested the lights and if they work, only that with the instruments of the car it does not, they have told me that it is a relay that there is to change, but I don't know where it is located, or a diagram to check the wiring may possibly be broken,
Eros Eduardo Hernandez Pa
In cars they usually have the fuse box next to the battery, they have a protective cover with 1 or 2 clips, open it and in the same cover it puts you in English so that they are the relaays (pictures that are connected) and the fuses ( like colorful ink cartridges), another place where you can find the fuses is on the dashboard of the car, they have a cover on the bottom of the steering wheel of the car or on the left side on the part covered by the door, if there is no cover you will have to directly disassemble that part of the board (Seeing your model is under the steering wheel of your car the other fuses) to check with the naked eye that they serve, the cover must show you with drawings what fuses they are, if they instead translate text in English translate it or if numbers come out then look in your vehicle manual for what are the fuses you have, with information about the fuse what should you change If you do not know how to check your connections, I strongly recommend you go to a technician, and if they are not the fuses, then the cable of your lamps may be damaged
