Automotive electricity
Nissan sentra engine Ga16741188R electric system review,
octaviocastillo
the problem commented by dragging the car without failure when traveling for about 6 kilometers, I let it cool for 2 hours, it began to show and it went on again and so it went on again and so it was still the same, I also want to have an elective maintenance. HELP YOU THANK YOU IN THE ENGINE COVER NISSAN TWIN 16VALVE IS OF THE YEAR 1996 CHASSIS # 3N1BEAB13S009455 ENGINE # GA16741188R
jorge lopezangel
Do it scan to see if it throws fault code, there I send you the complete motor electrical wiring and the electronic fuel controls, tell us as follows the subject, greetings. DownloadPdf.pdf [90.07kb] DownloadPdf (2) .pdf [386.75kb] DownloadPdf (3) .pdf [89.38kb] DownloadPdf (4) .pdf [658.49kb] DownloadPdf (5) .pdf [90.07kb] DownloadPdf (6) .pdf [275.84kb] DownloadPdf (7) .pdf [386.75kb] DownloadPdf (8) .pdf [151.21kb] DownloadPdf (9) .pdf [86.17kb]
octaviocastillo
Thank you, I thank you very much, your diagrams are fantastic. Jorge Lopezangel, I already tell you, I solved the problem by changing the electronic circuit that is used in a distributor, it is the power transistor that replaces the plates, this engine does not have a computer anyway, I need the diagram to The engine GA16741188R CHASSIS # 3N1BEAB13SOO9455 YEAR 1996 IN LATAPA DE VALVULAS WAS WRITTEN THE FOLLOWING NISSAN TWIN CAM 16 VALVE THESE DIAGRAMS YOU SENT TO ME WILL SERVE ME IN A FUTURE
