Hello, thank you for answering, now I'm going to look at that, I would have to take out the cover that is under the steering wheel and measure the key there, right? With a tester, could you tell me what “scale” I would have to put the tester on, and when would I have to give in and out? 12 v? Thanks for helping me, regards.
The most practical is a test lamp, but if you can also with the tester, it puts direct current on a scale greater than 12 v
Hello, I updated the post with images of where I put the test light, if you can guide me a little more I will thank you very much.
PS: is there any way to bridge the key or somewhere to see if the lights turn on? and how dangerous is that? thanks and regards.
Nono, the board doesn't turn on either. I looked at the rear lights and they are fine and at the front I looked at them, but without taking them out, and they seem to be fine, but by the doubts I will see if they are well taking them out.
UPDATE !!!! guys !!! long ago when I change the key of the light, never throw it away, and now look for it to try it! change the "new key that changed a while ago" to that old key that had been thrown since the change! since they don't know turn on the lights !!! with that old key, with which I suppose it is factory and change because it warmed me up! so it seems that after all the problem is the key, what I don't know now, is if that "new" key was spoiled by some problem ... or if it was spoiled just because they are bad ... But as I said! With the other key they turn on !!
You were the first one who told me about the key, I would love to be able to give you also as an accepted solution, since it seems that the problem is that, but I already gave an accepted solution to the other user. While he also told me that the problem was the key, he told me after you, sorry for my mistake.
It seems to me that I sings victortia too soon, with the key, old, the front lights come on but not the rear lights ... I don't know if it's because this "old" key is bad, or for something else ..
sorry, I comment again, I started screwing everything, the key, a little box that I don't know what it is, but I had to unscrew it, and the gun that I had taken out to see if there was nothing wrong behind, and I turned on the lights and now they turn on all the lights, maybe they did not turn on before because the rifle was not screwed to the chassis did not make contact, in short, everything seems to be the key, I will not have another, but to buy a new one and wait for the other one spoiled just because they are bad, and a few years ago I changed .. greetings and thanks to both! I tell you anything!
Sorry! I got confused!!! I wanted to give you a "positive" but I don't know why the problem continues, the horn is in the same light switch, and it works correctly, I tried two relays, and nothing happened, unless I had the bad one lucky that both are bad, and as for the red wire of the key, I put a wire to the chassis and another to the red wire and the test light turns on.
Thank you for helping me and sorry for the misunderstanding!
Sorry, I changed the key a while ago, because the one I had before, I suppose the factory ... heated it warmed until one day they didn't turn on the lights anymore, it didn't heat up, it worked properly until this happened.
Do you think it could be the key? Is there a way to open or repair or clean it on that key? Thank you.
and a bridge could be made in some way, to verify that the problem is the key? again thank you very much!
I mean ... it's not something simple to do ... I have a tester, but no idea how to make the bridge.
Here you have a lnk with plans I don't know if it's your model: https://yoreparo.com/vehiculos/electricidad/preguntas/955392/llave-de-luces-renault-12
And who keeps it, charges it, but you will have a key for more than 10 years (I clarify that the link is only by way of example): https://articulo.mercadolibre.com.ar/MLA-663463832-llave-luces-giro -bocina-renault-12-torino-jaeger-_JM
ufffffffff I see the difference! The keys I saw are for 250 or 300 pesos! justly! Thank you very much for your suggestion, I will have to see something that is better than those of 250 pesos, but less than this one that leaves 2500, at least for now until I can buy that jaeger, whenever I can I put the best to the car. greetings and thanks again!
