Automotive electricity
automatic transmission change to manual toyota 22r 1989
emilio
emilio
14
Good evening friends of I repair I have a pick-up toyota 22R 1989 model. I made a change from automatic gearbox to manual gearbox but lost power in climbs. The pickup is injected could you help me or guide me please
oscar yasinski
HELLO FRIEND, WHEN CHANGING A BOX YOU ALWAYS RISK THAT YOU PASS THIS AND IT IS NOTHING MORE THAN YOU CARRY A RELATIONSHIP BETWEEN BOX AND DIFFERENTIAL. WHEN CHANGING THE BOX YOU SHOULD CHANGE THE SPROCKET AND CROWN SET OF THE DIFFERENTIAL TO COINCIATE WITH SUCH BOX, OR RELATE. YOU HAVE TO FIND OUT WHAT KIND YOU CARRY THAT BOX. REGARDS .
emilio
emilio
14
In plan the pickup runs well and only on the rise or charged it no longer responds well it loses power I put the accelerator to the bottom and it does not feel that it responds and for the same reason. And thanks li I will see
emilio
emilio
14
Another question the pickup computer has nothing to do with changing the gearbox or is not related
oscar yasinski
HELLO I AM NOT SO MUCH SINCERELY, I WOULD BELIEVE THAT.
BUT WHAT MORE DOUBT I HAVE WITH REGARD TO CHANGE, IS IF YOU CORRECTLY READED ALL THE DRIVES AND CONNECTIONS OF THE AUTOMATIC, BECAUSE YOU DON'T FIX IF I HAVE ANY HOSE FROM THE MULTIPLE OF ADMITION THAT MAY TAKE AIR.
COMMENT
emilio
emilio
14
good afternoon gentlemen . thanks for your comments I tell you if you cancel all the connections of canbio of the synchronizer. change the differential
because the differential was different slow run erra and the other box I put was fast run then you have to put the same differential
and there I remain now if it responds well
