Automotive electricity
The coil does not generate a spark
Argenis_reparando
Chevrolet aveo 2007 does not generate spark plug spark plugs. So engine does not run coil was tested and it's ok
oscar yasinski
HELLO FRIEND, FIRST IDENTIFY AND CHECK THAT IT ARRIVES CURRENT TO THE COIL AND AFTER IT ARRIVES YOU CAN FIND THE SPARK CAPTOR OR SENSOR THAT IS THE ONE THAT GIVES THE ORDER TO THE IGNITION AND CHECK IF IT IS DAMAGED OR DISCONNECTED. BUT AS I SAY ON BASIS THAT IT COMES OR DON'T CURRENT LAYERS THAT WE LOOK FOR THE FAILURE ON THE OTHER SIDE. REGARDS .
