Hello everyone, please I need a help and to connect the automatic cable of a Ford Chillon boot. Then you can see the diagram as this part, I just need that cable. Very grateful
The automatic cable, which comes from the key, you have to connect it to the "S" terminal of the "pig" (the one between the battery and the starter motor), and in the starter motor it makes a bridge between the positive (which marks with red) and the automatic control (the terminal that marks with green). If it takes to start, the other fine terminal of the "pig", connect it with the positive of the ignition coil.
