Automotive electricity
witness temperature golf a2 (1991) since I turn it on
José Manuel Calderon Tina
regards... I have an A2 golf and since I turn on my car, the temperature warning light turns on and I can change the sensor and the weird harness that sometimes with a blow on the board goes out. I hope your help thanks
goneze
goneze
43
Hello, did you check the engine and chassis masses that are not sulphated or in false contact?
BIN2013
BIN2013
2.689
friend controls the board connector may be dirty or wet !! take out the board disconnect it and check the pins of the board and the connector! if you see moisture dry it with alcohol or some solvent and connect it again !!
is it very difficult to disconnect it? I have taken it out, I don't know if it is very complicated to disconnect and connect it again.
BIN2013
BIN2013
2.689
No friend is very simple if you can upload an image and say how!
thanks friend I will try and tell you ..
