Automotive electricity
Lancer 2002 1.6 I remove any battery cable and turn off
Hector692
My problem is with a lancer 2002 motor 1.6 I remove the positive cable from the battery and turn off buy a new alternator and the same problem has already changed the alternator 2 times and the battery is new check all the fuses and everything is bn please any help c thanks
Jjn
Jjn
Jjn
5.128
That is not a problem, when disconnecting the battery from the system: the alternator can send voltage peaks that exceed 16v and hopefully the ECU or other component is not damaged. It is not a 1960 car to be able to do those tests.
If the battery receives from 13.5V to 14.5V with all the accessories on; The alternator is charging well.
dbtt
dbtt
2.067
CHECK THE VOLTAGE REGULATOR? TEST ALSO THE BATTERY VOLTAGE OFF AND ON, TO SEE IF THE ALTERNATOR SENDS VOLTAGE TO THE BATTERY
Hector692
The two 2 alternators that have been tested are new and if you are sending power to the. Drums .
dbtt
dbtt
2.067
The idea of testing the voltage on and off is not to test if the alternators are new, it is to see how the voltage arrives (sometimes the wires are bad and they send intermittently, sometimes the regulator does not regulate, etc.)
